HELP, obd1 plug swap for ecm conversion LT1
Old Nov 6, 2021 | 05:08 PM
meanGTO's Avatar
Hi, I have a 97 ss camaro. I would like to swap to obd1 to tune it for free. I have the ecm. I have tuned an lt1 swap before 96 with obd1 computer and obd1 plug. I have the y cable with both obd1 and 2 connectors. If I swap the 95 ecm in, must I swap the diagnostic plug to obd1 style as well or can I write tunes and stuff through the obd2 plug with tuner pro. If I must change can you please provide pin out and what style obd 1 to order
thanks!
Old Nov 6, 2021 | 08:15 PM
Re: HELP, obd1 plug swap for ecm conversion LT1
Shoebox has the pinouts for the 1993-1997 LT1 DLC's:
http://shbox.com/1/DLC_wiring.jpg
Assuming you have the OBD-1 PCM used in both the 94 and the 95 F-Body LT1, you could go with 94 12-pin, or 95 16-pin. Just has to match the correct diagram.
Old Mar 9, 2022 | 10:14 AM
600RR's Avatar
You really only need to change the knock sensor for the ob1 swap. My 97 is obd1. Easy to do.
97Z-pimp
Oct 2, 2007 03:22 PM
Tricked-Out-Toy
Parts Wanted
Aug 6, 2007 04:59 PM
RE AND CHERYL
Mar 9, 2005 08:04 AM
Z97LT1
Oct 12, 2003 04:10 PM
ucrazymonkey
Apr 29, 2003 10:54 PM
