HELP!!!! need answer quickly.....
Old Jan 9, 2006 | 05:24 PM
devilisht2003's Avatar
Exclamation HELP!!!! need answer quick.....o-ring fell in....
was workin on my car and an o-ring from one of the injectors stick in the hole....when i tried to pull it out it fell into the hole....can it stay and just burn up or do i need to take the intake and stuff off to get it out??????
Old Jan 9, 2006 | 05:49 PM
Re: HELP!!!! need answer quickly.....
saw one thread where a guy just started up and it came out the exhasut.....should i do that or take the intake off?
Old Jan 9, 2006 | 05:51 PM
Johnny Ray's Avatar
Freebird
Since it is rubber I would chance it and go ahead and start it up after getting done working on it.
Old Jan 9, 2006 | 05:57 PM
amean94ta's Avatar
it will not harm anything fire it up
Old Jan 9, 2006 | 06:07 PM
ok i'll try it thanks
Old Jan 9, 2006 | 09:28 PM
Kataklysm's Avatar
Take it out. Why are you going to run foreign materials in the combustion chamber? You can probably fish it out with a pick. Not to mention without the o-ring sealing the injector you will spray some gas out into the engine compartment. You're next post will be... "why does my car smell like gas?"
Old Jan 10, 2006 | 10:08 AM
mr_camaro96z28's Avatar
You have to have an o-ring on the injector and I would NOT run it throught the engine. Granted you could get lucky and not hurt anything but it could also cause problems if it gets into the wrong places. A few hours to fish it out or pull the intake or alot of hours and money if you hurt the engine.
Old Jan 10, 2006 | 11:01 AM
Johnny Ray's Avatar
Freebird
What happened?
Did you start it up or not?
Old Jan 10, 2006 | 11:12 AM
johnny6's Avatar
Originally Posted by Johnny Ray
What happened?
He's too busy putting out the fire
Old Jan 10, 2006 | 11:59 AM
no i started it and drove it a little last night and some today and its runnin fine...went to auto zone and got new orings before i started it though and replaced the missing one...i wasnt that stupid
Old Jan 10, 2006 | 12:14 PM
johnny6's Avatar
Did you get the old ring out?
Old Jan 10, 2006 | 01:12 PM
Dave89IROC's Avatar
I have started a few up when a injector oring falls in, wrst I've had happen was a mis for a second as the oring got caught in the valvek, rev it up a little, and it smooths right out
Old Jan 10, 2006 | 01:34 PM
didnt just went and got the new ring...put it on... bolted everything down...hoped for the best and started it.
Daluchman1974
Sep 11, 2015 06:12 AM
cmsmith
Aug 9, 2015 07:30 PM
michaelzilinski
Jul 31, 2015 08:41 AM
NewsBot
Jul 29, 2015 08:10 PM
Latronaxe
Jul 20, 2015 12:00 PM
