Help with mirror install
I am trying to install a electrochromic mirror from a corvette into my camaro. I am having trouble with the electrical hookup, more specifically, the courtesy illumination. I have found out that the camaro has 3 wires, (Blue=Power Feed, White=Power Rtn, and Black=Ground), and that the corvette has 4 wires,(Orange1=Power Feed, Orange2=Courtesy Feed [From Relay] Brown=Guage Illumination Circuit, and Black=Ground) My problem is that if I hook up the Blue and Black wires, I do not have courtesy Lights. I am trying to find a circuit that actiuvates with the door switch and the interior light switch on the dash. I have tried to hook up the white wire to the second power slot, but all it does is keep the map lights on all the time, except when I switch the interior lights and then the turn off, (basically it operates backwards) Anybody with any electrical knowledg, your help would be greatly appreciated.
Thanks for Looking
Thanks for Looking
Camaro..........................Corvette
Blue-power feed..............Orange1-power feed
Black-ground...................Black-ground
White-power return..........Nothing (capped off) I'm assuming that this goes back to the BCM. Many of the Camaro circuits have to return though the BCM to function properly.
....................................Orange2-courtesy feed. Your going to have to find a hot lead that only comes on when the door is open or the interior lights are on. (i.e. from the light switch.)
....................................Brown-guage illumination. Same here only from the gage lights. (i.e. dash lights)
Obviously hooking the BLUE POWER to BLACK GROUND isn't going to work.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
guruerror
Dec 12, 2020 06:32 PM
