Help me identify oil leak!!!
Old May 5, 2017 | 10:53 AM
Houston_Z28's Avatar
My car leaks oil from the front off the timing cover always about a nickel sized leak Everytime I park the car. If I wipe the bottom of the timing cover dry it takes about a day and a half for it start leaking again. The oil collects on the air pump line that runs along the bottom of the timing cover the timing cover is dry expect for the very bottom where you use to line up the crank hub. On top of that if I jack the car up it leaks from the back and not the front. My starter bellhousing and flywheel cover are covered in oil. I think it could be intake gasket and the rear the dipstick or maybe the oil cooler?
Old May 5, 2017 | 10:56 AM
Re: Help me identify oil leak!!!
https://goo.gl/photos/wrmZNhocdQnhH4HT9
thats a picture of the back of the intake.
