HELP with driver side window
Old Jul 14, 2006 | 01:18 PM
mfb_lt1birdman's Avatar
My car was in the shop for a week or so. My drivers side window worked b4 dropping it off, although it was a lil slower than new. However it never once froze up while going up or down as the classic motor failures do. So it failed suddenly without warning-luckily its up. I dont here any operation from the motor when depressing the switch. I have replaced this motor once b4 too.
I need to know what else besides the motor it could be b4 pulling it apart cause i have never heard of these failing suddenly like this-(i just searched many threads here and on ls1tech) My passenger side still works btw. Thanks.
Old Jul 14, 2006 | 01:26 PM
2001NBMZ28's Avatar
Re: HELP with driver side window
You can look at the switch, but one of mine died suddenly after it only being slow for while and doing the hesitation thing a couple times.
Old Jul 14, 2006 | 01:46 PM
How can I check the switch?
Old Jul 14, 2006 | 01:56 PM
With a meter and a schematic. You can also try jumpering power and ground to the motor to see if it works.
Old Jul 14, 2006 | 02:12 PM
Shoebox can you elaborate on the test? I do have a multimeter but I'm ignorant when it comes to this electrical stuff. Thanks.
Old Jul 14, 2006 | 03:39 PM
It's impossilble to school someone on reading schematics in a thread like this. I'll try the Cliff Notes version.
terminal positions
The following is tested on the switch (disconnected from the car)
LH switch not operated:
you should have continuity from:
A to D and E (and to B and C of the RH switch)
LH switch in UP position:
D to F
A to E
LH switch in DOWN position:
F to E
A to D
I hope I got it right.
Old Jul 14, 2006 | 03:47 PM
2001NBMZ28's Avatar
Mine's the passenger side and won't work with either door switch, drivers side is fine. Your's is most likely the motor too.
Old Jul 14, 2006 | 04:48 PM
rooster99ss's Avatar
hate to be the bearer of bad news, but replacing driver's side window motors often is just part of owning an f-body. I've had 2 4th gens and both of them wound up making me replace them. A little trick to making them last a little longer is not letting the window go all the way down on the one touch express down...it makes the motor bind up for a couple of seconds after the window goes all the way down, ruins the motor.
Old Jul 14, 2006 | 06:55 PM
OK i found out the motor is ok but with the motor disconected from the window gear the window switch only makes it go up. Nothing happens when I push down. Now what?
Old Jul 14, 2006 | 09:52 PM
For the heck of it I swapped the actually gray button from the passenger side control to the drivers side and presto. Thanks for the tip in your write which i skimmed too fast shoebox. You the man with all those right ups and tech info Now I just need a new button.
Keenan
Jan 19, 2023 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
