HELP: Check Gauges Light, Oil Pressure?
Old Aug 31, 2007 | 11:45 PM
pgraves's Avatar
Question HELP: Check Gauges Light, Low Oil Pressure?
Well, I am finally driving my Camaro (1995 V6 3.4L) around again, just got it officially out of the shop yesterday (I did get to drive it briefly in between a series of scheduled repairs over this past week, but tonight was the night that it was to finally go home). However, as I was driving around tonight, feeling good, my "Check Gauges" light came on for the longest time. I took a look at my gauges, my temperature was fine, gas was fine, battery was fine, but Oil Pressure "looked" a little low.
My question is: When driving around where should my oil pressure gauge be? I *THOUGHT* it was supposed to be about the half way mark. However, when I was driving around it was about the 1/4 mark.
Let me know what you guys think
Old Sep 1, 2007 | 10:06 AM
CheshireCat's Avatar
With the engine warm, you should see anywhere between below the 1/4 mark at idle to above the 1/2 mark at higher rpm.
Old Sep 1, 2007 | 10:27 AM
pgraves's Avatar
So when I am driving around the mark should be above 1/2?
Old Sep 1, 2007 | 02:36 PM
pgraves's Avatar
Ok, I drove around today and it stayed around the 1/2 mark untill just a few minutes ago. After driving for sometime I happened to stop at another red light, this time the oil pressure dropped STRAIGHT TO ZERO and of course my Check Gauges light came on. Then after that when I am driving around my oil pressure stayed at about the 1/4 mark but at every red light after that it went STRAIGHT BACK TO ZERO while I idled. This car recently blew a headgasket and I JUST GOT IT OUT OF THE SHOP day before yesterday, so could the blown headgasket be related to this? What do you guys think is the problem? or the cause of the problem?
Old Sep 1, 2007 | 02:59 PM
Dave89IROC's Avatar
does it sound like its losing oil pressure?
if not, get a mechanical gauge on it, and if the psi is good, replace the sensor
Old Sep 1, 2007 | 04:40 PM
pgraves's Avatar
Car drives/sounds fine. I dropped it off at my Mechanic, they were closed but my Mechanic happened to be there. He said he can't look at it till Tuesday (closed for Labor Day) but that more than likely it is just like you said, a sensor. So we shall see.... luckily I have a Mitsubishi 3000GT SL to drive as my back-up car for when the Camaro breaks down (I love my camaro but I have to admit, it has problems.... A LOT)
HectorM52
Jul 30, 2017 11:46 AM
NorthPoleDev
Dec 31, 2014 03:20 PM
cmdeshon
Dec 27, 2014 10:06 AM
ro2207
Dec 4, 2014 06:18 PM
Jul 4, 2005 05:00 PM
