Heater core replacement procedure?
Old Aug 25, 2011 | 05:14 PM
2QUIK6's Avatar
Is there a writeup posted somewhere on how to replace the heater core?
Does the dash have to be removed like the 3rd gens?
Old Aug 25, 2011 | 06:19 PM
bw_hunter's Avatar
Re: Heater core replacement procedure?
The first place to look with a question like this is Shoebox's site. Www.shbox.com
It's there....
Old Aug 25, 2011 | 06:27 PM
Actually, it's not.
It is very simple, though. Remove hoses and the clamp between pipes in the engine compartment. Remove lower RH dash panel (and glove box, if you need room). Remove cover on HVAC housing to get to the core. I think there is a bolt/clamp in there on the core, IIRC. Wrangle the core out and reverse to install.
Old Aug 25, 2011 | 06:36 PM
bw_hunter's Avatar
Originally Posted by shoebox
Actually, it's not.
Sorry, I must have been thinking evaporator core....
Old Aug 25, 2011 | 07:05 PM
2QUIK6's Avatar
It's there....
Yeah did that and a search on here, reason I posted
Ok, so it will come out by removing the lower PS under dash cover and the glove box. Was hoping I wouldn't have to pull the entire dash cover like I did on the '89 a few years back!
Thanks for the reply Rob!
Old Aug 25, 2011 | 07:30 PM
I think someone posted a step by step in the general tech forum some time ago. It should be close to what I said.
alex5366
Mar 8, 2015 11:32 AM
alex5366
Feb 17, 2015 10:43 PM
kksi
Feb 17, 2015 10:41 PM
Britbilly
Jan 7, 2015 08:49 PM
Black93lt1
Nov 21, 2014 07:30 PM
