heater core
Old Oct 15, 2012 | 01:09 PM
Lilatlboy6969's Avatar
heater core
ok im looking at getting a new heater core for my 95z.. here lately if i've been recently running heat in my car and then turn it off and crank it back up shortly afterwards the windshield will fog up. so the only suspect could be the heater core to my knowledge. but the main reason im here is asking you guys are the heater cores from summit racing just as good as an ac delco one? because there is a 70-80$ difference in price.
I dont drive it much in the winter nor do i use heat too often but it is nice to have so i dont want to get rid of heat but i also dont wanna spend close to 200$ on a heater core when i dont use it enough
Old Oct 15, 2012 | 01:33 PM
97z28k&N's Avatar
I bought a heater core for $40 new on ebay and it is extremely comparable to the one I pulled out (stock).
Posted from Camaroz28.com App for Android
Old Oct 15, 2012 | 02:01 PM
RamAir95TA's Avatar
Re: heater core
Your window fogs up because moist air is being blown onto your windshield. When you turn on the defroster the A/C kicks on to dry the air being blown across the heater core. Verify the operation of your A/C (if it has not been deleted).
If the heat is warm when the selector **** is NOT in the defrost position then there is nothing wrong with your heater core.
Old Oct 15, 2012 | 11:35 PM
Z28SORR's Avatar
Re: heater core
It, the water, should also smell and feel like anti-freeze.
Old Oct 16, 2012 | 04:44 AM
RamAir95TA's Avatar
Re: heater core
Say what?
Old Oct 16, 2012 | 03:31 PM
I've flushed my heater core 3 months ago and swapped dexcool out for antifreeze. My heat doesn't blow hot by any means. Its more like Luke warm and mu AC blows ice cold. There's no leaks in the system that I can see under the hood but from time to time I used to smell dexcool in my car but no wet carpet yet.
Can I pressure test my car when cold to see if there's any leaks in the heater core?
Old Oct 18, 2012 | 06:41 PM
Any ideas?
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
