Hatch Strut Mount broken
Old Jun 7, 2005 | 10:22 PM
3gc's Avatar
3gc
Yesterday i was looking at my car attempting to find the source of a few noises i get while going over large bumps and i noticed that the hatch side of the hatch strut mount is broken. I didn't get a chance to take the plastic trim panel off yet but it seems that a peice of fiberglass ripped off with the hatch strut. It still lifts the hatch but I can move the strut around. If i get time tomorrow i'll take the trim off and maybe repair it. I was curious if anyone else has had this problem.
Old Jun 8, 2005 | 01:42 PM
3gc's Avatar
3gc
Re: Hatch Strut Mount broken
I did some investigating today and noticed that a fiberglass peice didn't break off. It's a peice of metal that is glued to the fiberglass. I attempted to epxy it back on. The package said it takes 5 minutes to set and the stuff i mixed turned hard as a rock in about 5 minutes so i gave the hatch a good half hour before i reattached the strut. As soon as I did and put the weight of the hatch on it, it broke. Anyone have any other ideas?
http://3gc.net/misc/hatch-strut-mount.jpg
Old Aug 27, 2005 | 10:51 AM
rckrzy1's Avatar
Yep found mine broken yesterday, must be the 10yr old glue gone bad. I tried JB weld and it popped to.
Old Aug 27, 2005 | 05:49 PM
rckrzy1's Avatar
Ok fixed mine with 2 3/16 pop rivets and epoxy. I drilled 2 holes through hatch and metal plate that is loose, then used some of that epoxy you knead together and pushed that in between the fg hatch and metal piece and pop riveted, worked great.
Old Aug 27, 2005 | 10:30 PM
3gc's Avatar
3gc
I learned to live with it for the past few months. What did you do to use the pop rivets? The metal peice seems to be only slightly bigger then the hole in the hatch.
Old Aug 28, 2005 | 12:03 AM
rckrzy1's Avatar
I had ample room to get the 3/16" pop rivets in. The lower section actually goes far towards the hinge end and and the other I put right in that ring.
realistyc
Jul 28, 2015 07:32 PM
Fastbird93
Jul 11, 2015 04:37 PM
Jul 10, 2015 02:23 PM
mrwz28
Jul 8, 2015 09:11 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
