has this happened to anyone before?
Old Jan 31, 2013 | 10:06 AM
Big Zeus08's Avatar
So unfortunately the other day I was at school and it started snowing and I got stuck driving my 2000 camaro ss back on the lovely slush/snow covered roads sliding all over the place. At a particular slight uphill my shifter started hopping up and down in the console. I'm assuming this is just wheel hop but I wanted to double check since it was alot of movement and I've never seen it before. Could I possibly have a loose transmission brace? who knows, thanks guys
Old Jan 31, 2013 | 10:10 AM
Ultra_Z's Avatar
Re: has this happened to anyone before?
no, but your tranny mount maybe shot to hell! does ur shifter move a lot to the right when in gear when u jerk the gas pedal down real quick like a quick rev in gear at 2000 rpms...? if it moves more that a 1/4 inch u need a tranny mount. very easy to install! get a poly one!
Old Jan 31, 2013 | 10:17 AM
Big Zeus08's Avatar
I've honestly never noticed this before but ill try it out to see if it does. I might just replace the mount anyway. I just bought it in august so I have no idea if was replaced or not
Old Feb 9, 2013 | 05:06 PM
flexus's Avatar
I would definitely get a poly bushing in there, not harsh to run, cheaper than the stock rubber and you know it won't give in that easily
Old Feb 20, 2013 | 05:10 PM
rv93's Avatar
isnt there an issue with running harder trans mounts than engine mounts? or is it the other way around?
Old Jun 24, 2013 | 04:25 PM
flexus's Avatar
I've run poly trans for years before getting engine poly. Worked fine in both setups, and weren't uncomfortable at all. I put poly mounts in a TJ Wrangler once and it shaked like a wet dog!
Novo
Jun 14, 2016 02:58 AM
Daluchman1974
Sep 11, 2015 06:12 AM
damnyankee36
Sep 9, 2015 07:06 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
