Hard loud knock underneath my center console???
Old Aug 23, 2011 | 10:40 PM
SmittyLS1's Avatar
ok so i have a 99 Z28 6 spd and tonight i was out cruising around and i smell this god awful smell and i was thinking shoot smells like my clutch is hot so i headed towards home( 6 blocks away) and on my way home i here this loud knock like something was hitting up thru my center console and every time just let out on clutch to give it gas it would knock or every time i let off gas n low gears any ideas??? (i just had the clutch rebuilt not even 3 weeks ago)
Old Aug 23, 2011 | 11:00 PM
8cylinders>4's Avatar
Re: Hard loud knock underneath my center console???
Its kind of weird the sound included a smell of burned clutch, because otherwise a loud knock from that area is caused by a broken tranny mount
Seeing as how the clutch has recently been worked on, it could possibly be the issue. Was the clutch noticeably slipping?
Old Aug 24, 2011 | 08:27 PM
JooneJune's Avatar
Tranny mount is shot... get a new one...
Old Aug 25, 2011 | 06:47 AM
Procharged94Lt1's Avatar
Start with trans mount- if smell continues you have other issues, but the clunk is the tranny hitting the tunnel.
Old Aug 27, 2011 | 01:06 PM
SmittyLS1's Avatar
well actually the smell was from something else you now smell it every time you go over the bridge over the tracks... but it actually was that long arm that is right next to driveshaft the bolt on the top side of bracket vibrated out and every time i gave it throttle that arm swung up and hit right under console right next to armrest area... so put a new bolt in and haven't had problem since... idk what that arm is called or bar is called... but that was the problem.... thanks for comments guys this message board is really helpful...
Old Aug 27, 2011 | 02:53 PM
That would be the torque arm.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
mattstrike
Mar 11, 2015 07:33 PM
CaRParts102
Dec 6, 2014 08:45 AM
x7x7
Aug 15, 2002 06:49 PM
