is this a good way to get rid of vats
Old Sep 23, 2008 | 04:17 PM
jamilz28's Avatar
will this really get rid of the pain in the *** vats system. If it will work it looks easer then matching it up to the sensor in the key to a resistor.
http://cgi.ebay.com/ebaymotors/GM-VA...QQcmdZViewItem
Old Sep 23, 2008 | 04:55 PM
It does simulate the signal needed to go to the PCM, but if you have a key pellet problem, you won't be able to engage the starter unless you bypass the pellet or the TDR. You have to know how the whole system works (explained on my Tech Page).
Old Sep 23, 2008 | 06:28 PM
Green96Z's Avatar
"This VATS bypass module is intended for use when installing a GM engine equipped with VATS (Vehicle Anti-Theft System) into a vehicle missing the BCM"
This is useless in an F-body, unless you have eliminated your BCM. It does not eliminate the common key reading problem.
Old Sep 25, 2008 | 04:11 PM
94arcticwhiteM6's Avatar
id say use resistors or have it edited out.
Old Sep 28, 2008 | 08:01 PM
Dave89IROC's Avatar
if edited out, you still need to rewire the TDR
Old Sep 28, 2008 | 08:09 PM
shock6906's Avatar
I just used a resistor. Cost me a whole dollar and took about ten minutes of my time. Haven't had an issue since.
Old Sep 28, 2008 | 09:17 PM
Johnny Ray's Avatar
Freebird
Can you go into detail on how you did it my friend?
A few are interested in doing that to our f-body cars.
Thanks!
Old Sep 28, 2008 | 09:57 PM
Thanks!
All you need to do is read... http://shbox.com/1/pass_key.html
Old Sep 29, 2008 | 06:28 AM
shock6906's Avatar
Thanks!
It's been a while since I was under there to do it, so I'll have to get back under the dash and check it out again. I remember it for the most part, but I don't want to give any bad information. I'll go back under it and get some pictures this afternoon. I did get all of my information from shoebox's website though.
Noer
Feb 28, 2015 11:29 AM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
k1996z28
Jan 21, 2015 07:22 AM
Fbodfather
25
Jun 21, 2002 04:12 PM
