Get a bad gas smell in my car at 60mph+
Old 12-12-2004, 03:17 PM
crAzy95z28's Avatar
why is this?
crAzy95z28 is offline
Old 12-12-2004, 09:16 PM
Kataklysm's Avatar
Re: Get a bad gas smell in my car at 60mph+
Check for leaks/cracks in/from the manifolds. You could have a gas leak which wouldn't be good too. Look around for wetness near the fuel rails and fuel lines.
Kataklysm is offline
Old 12-12-2004, 11:10 PM
crAzy95z28's Avatar
but this only happen after i took out my sedning unit and changed it!!!
i think i may have knocked open a gas line or something!!!
sorry im a lil intoxicatd, i cant think of the name im trying to thingk of!!
sorry!!!
lol
ranydy
Old 12-14-2004, 12:00 AM
XxXTransAmXxX's Avatar
Did the car have any amplifiers, or anything mounted in the rear deck lid? If so chances are whomever mounted it, used too long of screws and pierced the tank, which alot of people over look the tank being so close to the sheet metal....When you sober up hopefully you can supply more info...
XxXTransAmXxX is offline
Old 12-14-2004, 12:04 AM
crAzy95z28's Avatar
well what happen was it started to smell after i messed around the sending unit taking it in and out bout 5 times!!!
i amde sure the rubber piece was sealed, but i think i may have knocked opne a vacuum line for the fumes!! or somthing!!
Randy
Old 12-14-2004, 08:45 AM
ishz28's Avatar
That's what happened to me after the butt monkey at Best Buy installed my radio set up. The drilled the amp right into the tank. Not to hijack your theard, but it seems you answered you own question. What would cause my gas cap to back off? Every so often I smell gas when I shut the car down only to find that the gas cap is loose??
ishz28 is offline
Noenav
12-06-2014 07:35 PM
blac94Z
11-28-2014 01:53 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
blac94Z
11-24-2014 07:12 PM
USAirman93
11-24-2014 03:37 PM
Quick Reply: Get a bad gas smell in my car at 60mph+
