Gear selecter question
Old Apr 27, 2012 | 12:16 PM
Lilatlboy6969's Avatar
OK so I have my 95z with a 4l60e with a 2.73 rear end. I can't put my shifter into first gear and I've read on ls1 tech that all I should have to do is pull the plates out of the center console and take the "button" that is blocking 1st gear selections. Just wondering if anyone has any knowledge about doing this. Are there any negative effects of doing this? Thanks a bunch
Old Apr 27, 2012 | 01:26 PM
bombebomb's Avatar
Re: Gear selecter question
Sorry for not answering the question, but why exactly do you want to be able to manually place it in 1st gear?
Old Apr 27, 2012 | 01:40 PM
96capricemgr's Avatar
the 2-3 shift gets more line pressure if the selector is in OD, a good reason to not worry about manually selecting gears.
Even for a burnout you want to get the tranny into a higher gear to get wheelspeed up so manual 1st is not good there, though with factory programming it will I believe upshift to 2nd anyway.
Old Apr 27, 2012 | 01:58 PM
RamAir95TA's Avatar
If you take off the center console you will see what you have to remove. It's very basic.
Old Apr 27, 2012 | 02:21 PM
Kevin Blown 95 TA's Avatar
Yeah it's just a little tab you can remove with a knife
Old Apr 27, 2012 | 09:03 PM
eventually after im done building the motor a little more and the rear end then 1st gear will be more of a use. and i think i have authority problems and i dont like gm telling me i cant manually shift into 1st. lol
also i havnt heard if there are any negative effects from removing this clip/button. i wouldnt understand why but i just wanna make sure removing it wont harm anything in my car
DirtyDaveW
Dec 1, 2016 05:37 PM
ddr698
Jan 9, 2015 10:05 AM
ChrisFrez
Dec 21, 2014 09:47 PM
Dec 17, 2014 11:00 AM
ChrisFrez
Dec 15, 2014 03:09 PM
