gauge Q?
Old Jul 2, 2004 | 01:33 AM
LetMeBurnU's Avatar
gauge Q?
I saw this camaro with a triple gauge pod and he has oil temp, boost, and vacuum. What is the purpose of the vacuum gauge and what does it read..?
Old Jul 2, 2004 | 02:23 PM
OBE1 95Z28's Avatar
Boost gauges also display vacuum. A vacuum gauge is used to monitor the intake manifold. Loss of vacuum would be a warning that you have a leak in your intake system that would cause poor performance.
Old Jul 3, 2004 | 02:39 PM
LetMeBurnU's Avatar
will the vacuum gauge work on a stock ls1..?
Old Jul 3, 2004 | 03:34 PM
n2ceptor's Avatar
Yes..... I just have a vacuum gauge to help me monitor my heavy foot.... You just splice into a vacuum hose with a three way connection..... At idle my vacuum is around 18 in hg, so on the highway I try and maintain that for gas mileage.... It helps..
Old Apr 6, 2006 | 08:29 AM
jarek5_7's Avatar
Re: gauge Q?
which hoose have You cut to install the Tfiting for gauge?
Old Apr 6, 2006 | 10:16 AM
94lt1m6's Avatar
Re: gauge Q?
^ any coming directly off of the intake manifold
Old Apr 6, 2006 | 11:09 AM
jarek5_7's Avatar
Re: gauge Q?
i connected it a while ago to vacuun in aircond. switch
Old Apr 6, 2006 | 02:46 PM
OBE1 95Z28's Avatar
Re: gauge Q?
I bet you'll get false intake vacuum readings connecting to this source; there's a vacuum reservoir in that line that will affect your readings. T'ing off a connection directly off the intake manifold provides an accurate reading. It will not matter much if the gauge is just for eye candy, but if you want to track down an intake leak it would make a difference.
Old Apr 6, 2006 | 02:51 PM
jarek5_7's Avatar
Re: gauge Q?
mhm are you sure there is a reservoir ? gauge responds emediatly to throtle.
at idle in P shows 20, in D around 19. I out vac bacause didnt knew what third gauge to instal i have tranny temp, oil temp, and vac in pilar.
Old Apr 7, 2006 | 09:55 AM
OBE1 95Z28's Avatar
Re: gauge Q?
See photo from Shoebox's site:
http://shbox.com/1/vacuum_tank.jpg
Old Apr 7, 2006 | 03:16 PM
Re: gauge Q?
Are you sure an LT1 4th Gen is the same as an LS1? I don't know the answer, but its something to keep in mind.
Old Apr 7, 2006 | 08:50 PM
OBE1 95Z28's Avatar
Re: gauge Q?
Good catch Fred, I didn't catch that it was an LS1. Still believe there would be a vacuum tank for the HVAC controls though.
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
