gas smell
Old Mar 5, 2011 | 09:26 AM
andresz28's Avatar
gas smell
Hey everyone out there just bought a 95 z28 noticed tho when I step on the gas it smells a lot like raw gas inside wanted to see if any one has has a problem like this before and what caused it
Old Mar 5, 2011 | 11:26 AM
Jason Dove's Avatar
Re: gas smell
It could be either a bad charcoal canister or a hole in the gas tank. Hope for the charcoal canister, it's a fairly non-expensive part, in the drivers side rear fender well behind a plastic panel.
If it smells stronger in that fender well then the pass-side fender well, my vote is for the canister. If it smells the same in both fender wells, probably a leak IMO.
Old Mar 5, 2011 | 12:25 PM
JustCruzin's Avatar
Re: gas smell
I agree. Also check your fpr for a leek in the diaphragm could back up in the vac hose. How does the car run otherwise?..Just a guess, hope you find the problem.
Old Mar 5, 2011 | 02:16 PM
Re: gas smell
The rubber hose on top of the fuel tank, that connects to the charcoal canister is notorious for rotting and falling apart. You'll get a strong fuel smell if that happens. I noticed it in the passenger compartment when stopped at a light with the driver's window open.
And, does your car have a cat? If not, the exhaust is going to smell of fuel.
Old Mar 6, 2011 | 01:36 PM
andresz28's Avatar
Re: gas smell
I did check the hose and saw its broke gonna replace appriciate the assist
Old Mar 8, 2011 | 10:29 AM
JustCruzin's Avatar
Re: gas smell
Glad you found it, hope it fixes the problem
Nayr
Mar 3, 2023 08:34 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
damnyankee36
Sep 9, 2015 07:06 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
Bails098
Aug 17, 2015 05:15 PM
