Gage illumination
Old Apr 25, 2010 | 09:13 PM
Joel-Lax's Avatar
Gage illumination
I have 97 z28. Recently my instrument cluster decided it doesn't want to illuminate anymore. The headlights and running lights work when you turn the headlight switch on but the gages and the odometer do not illuminate. I checked the fuse and the fuse for the gages is good. I started the car and checked to make sure the gages do function properly. I cycled the key and noticed the odometer display does show a couple red indicators as if the cluster does have proper power going to it. But i can not get the gages to light up or the odometer to read mileage. Has anyone run into this before? Thanks
Old Apr 25, 2010 | 09:25 PM
Sleepy_Z's Avatar
when adjusting the interior lights using the dimmer switch...
are the other interior lights affected?
Old Apr 26, 2010 | 06:39 AM
Joel-Lax's Avatar
No it checked that too. The dimmer switch does not affect the illumination of the gages. Or at least the dimmer switch does work properly for turning the dome light on like it's suppose to, but doesn't adjust the brightness for the gages. Gages are all dark. And the odometer doesn't turn on with adjusting the dimmer.
Old Apr 27, 2010 | 05:01 AM
Guest47904's Avatar
Guest
Did you check the 3 fuses??????? I/P #7,9,16. 16 is the dimmer fuse. That ones got to be bad.
1bad427ls1
Sep 23, 2015 01:12 AM
4586
Aug 24, 2015 11:04 PM
Collinjacobfowl
Jul 30, 2015 09:35 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
