Fuel tank and pump questions
Alright, im pretty sure I need to replace my fuel pump, and I have researched how to do the trap door method and it looks relatively straightforward. However, ive seen some people say its a bad idea because you are not able to flush the tank out. What all is involved with flushing the tank out and why is it not possible with the trap door method?
Re: Fuel tank and pump questions
I just did mine a couple weeks ago and didn't flush anything. Only way I would drop the tank - considering all the work involved - is if there were no other option. It wasn't a bad install at all.
I did this job 2 months ago when my pump spontaneously failed.
I cut the access hatch per the instructions on the web and it probably
took less than 2 hours for the whole job. Keep in mind the glue on the bucket has to sit for 24 hours during this process.
Its super easy to do, get the racetronix pump its a direct replacement
and it comes with Everything u need, including a paperclip
I read in GMHTP that you should flush out the tank using water, flushing it out is to get rid of any setteled sedement and rust out of the tank that could clog your new pump. You don't know if your old pump clog due to this floating gunk in your tank, so you run the risk of having your new pump fail shortly after install because of neglecting to flush out your tank.
Originally Posted by 93camaroLT1
although it makes life a **** ton easier, this trap door method is so ghetto.
Cutting off the top of your car with a sawzall to make a convertable out of it - now that is ghetto. Or taking a can of spray paint to your wheels to match the color of your car is ghetto.
I dropped my tank when the car was about 8 years old to replace the fuel pump. No signs of dirt in the tank and the stock filter sock looked fairly clean. I didn't bother cleaning my tank; not sure I would want to introduce water into my tank anyway...sounds like a good way to introduce problems.
i threw water into my tank when i was doing the trap door method cause i was worried about blowing up. then pumped it out with the fuel pump. 3 months later, no problem.
Deadbolt24
Jan 19, 2015 01:29 PM
guionM
9
Aug 29, 2002 01:48 PM
guionM
18
Jul 11, 2002 01:45 AM
