found out why my window is messed up..
Old Mar 24, 2007 | 04:12 PM
nodnarb481's Avatar
But I dont know what these things are or how to fix it so your help would be great.
here is what I found when I took the door apart
It looks like something was broken off where that hole is because its like sheered metal. That is some kind of bracket that I assume attaches to the track nearest to the outside of the door
Here are two parts I found inside the door
Basically that track isnt connected to the window and I dont know why
now I gotta figure out why my ABS light wont turn off...
Old Mar 24, 2007 | 05:18 PM
I believe there should be a roller attached there that guides the window up and down in that channel to the right.
Old Mar 24, 2007 | 05:38 PM
nodnarb481's Avatar
there is.. i pushed it up and down and its in there.. but its not connected.. and thats where I am lost. I dont know how it connects all i know is that the bigger of the two pieces that are in the second picture was connected to it almost like it was magnetic or just stuck because of all the grease in there
Old Mar 24, 2007 | 08:36 PM
shock6906's Avatar
Same thing happened to my window. I'm going to guess it's the driver's side? That metal stud has the small lip at the one end of it that connects to the metal plate on the regulator. I temporarily fixed mine by pushing it back in there and squeezing it back down with some pliers. It's not perfect, but at least the window doesn't roll back and forth now.
Old Mar 25, 2007 | 01:43 AM
nodnarb481's Avatar
soo you think i could push the side with the lip back into the slider on the track and then i guess i would squeeze the ball end through the hole in that metal plate adjacent to it? I think that might work I guess ill give it a shot
Old Mar 25, 2007 | 08:34 AM
shock6906's Avatar
Yeah man, that's all I did. I had to open it up a little first before that lip would fit back through the hole, but after that, I just squeezed it together with some slip-joint pliers and it's been fine since. Like I said, it still isn't perfect but it's not sliding back and forth inside the door anymore.
Old Mar 25, 2007 | 08:38 AM
nodnarb481's Avatar
yea.. i wonder how much it would cost to have that part replaced... probably a lot i would expect.. Im gonna see what I can do about it today..
Old Mar 25, 2007 | 11:22 AM
NovaTodd's Avatar
Try these guys: http://www.crlaurence.com/ Searrch in the automotive section and see if you can find one the correct size
Old Mar 25, 2007 | 05:19 PM
nodnarb481's Avatar
i dont know what it is.. i was going to see if I could buy that plate section thats in the picture but everything is all riveted together.. I think i onl yhave two choices.. figure out how to get the bowling pin thing back in or take it to the dealership because i dont know if any shops around here would work on that window... that would cost a fortune tho
Old Mar 25, 2007 | 07:29 PM
nodnarb481's Avatar
so i went to my friends house (he has tools) and we popped the bowling pin thing back into the slider on the track using a table clamp. i bolted the track back in to the door and then did a lot of manuevering and with some channel locks got the other side into the bracket. Its not in good tho. I know if i used the window it would come right off so I JB welded the **** out of it and clamped it down for the night and ill check it tomorrow afternoon.. hopefully that stuff is strong enough to hold it
Old Mar 26, 2007 | 09:50 AM
nodnarb481's Avatar
i got mixed answers on whether or not the JB weld will hold.. anyone have an opinion on it here?
Old Mar 26, 2007 | 07:57 PM
shock6906's Avatar
Well I didn't use any JBweld or anything on my car and it's been holding up since then and I use the windows daily. I think I did my repair about 5 or so months ago and I haven't worried about it since.
Old Mar 26, 2007 | 08:30 PM
nodnarb481's Avatar
mine is a little more involved then i thought.. there is something else broken I cant see so that jb weld didnt hold with all the extra stress on it.. oh well im just taking it to the shop to have a new regulator put in
Old Mar 26, 2007 | 09:49 PM
ACE1252's Avatar
Best thing to do is replace the regulator piece that attaches to the window. I did it myself and it's not too bad. Using Shoebox's site and watching out for the powerful regulator spring, things went well.
Old Mar 26, 2007 | 09:55 PM
mdacton's Avatar
I had the same problem...anyone know where to get that part that goes on the window? with the little stud on it?
I tried to weld it back on and did but It got too hot and burned the little wheel off
