Fog Light Mod
Old Feb 2, 2005 | 04:59 PM
JAG05's Avatar
Fog Light Mod
Ok I just sent an hour trying to figure this mod out. I took a peice of telephone wire and stuck down in the relay hole and stuck the relay on top of it and than grounded that wire, to see if it worked. And it did but it was such a little wire it got hot very quickly. So i just a bigger wire. When i did that the dim and fog lights worked fine but when i swich to brights the fog lights worked but the bright lights flickered on and off. So i thought it may be the bigger wire wasn't going down in teh relay hole far enough so i striped the wire and hooked it right to the wire and grounded it, i didn't completely cut the wire just sliced into it. And it did the same thing flickered on and off. Whats the problem?
Old Feb 2, 2005 | 05:48 PM
JAG05's Avatar
Re: Fog Light Mod
Anybody?
Old Feb 2, 2005 | 06:11 PM
Brent94Z's Avatar
Super Moderator
Re: Fog Light Mod
Hey Bud!
1) You need to wait a little longer than you did for an answer. Usually about 1 day before you "TTT" it please.
2) Wrong forum. This is for LT1 Engine tech. I'll move it to the General Tech forum for ya.
Old Feb 2, 2005 | 06:59 PM
Z28Nut's Avatar
Re: Fog Light Mod
Uh, I did the mod and cut the green wire going to the relay and then grounded the relay side of the wire. The other cut end gets capped. It sounds like your shorting something out.
Old Feb 2, 2005 | 07:01 PM
kingman109's Avatar
Re: Fog Light Mod
i think i got away with a 18 gauge wire fine when i did mine in my last car... just spliced it and grounded per instructions
took about 5 min to complete and had no problems.. your doing something wrong... give it another look
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
alphaauto
Jan 23, 2015 07:42 AM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
