Flow Masters....And the benfits
Old Dec 12, 2004 | 10:14 AM
JaxCamaroGuy's Avatar
Ok, im about to have some exhaust as my first mod put on my 96 black camaro, v6, umm what are the benefits of having something like flow masters put on there, i know it says it increases fuel economy and power, but do they REALLY do that, i wanted you guys opinions, thanks!
Old Dec 12, 2004 | 10:39 AM
moparman's Avatar
Re: Flow Masters....And the benfits
There have been some threads on here that would indicate there are better choices than Flowmaster. However, those threads had to do with V8s, might be different for a V6.
Old Dec 12, 2004 | 11:10 AM
teke184's Avatar
a muffler is basically a restriction in the exhaust flow. the more restriction (generally) the more it quiets the sound.
the less restriction the easier the engine can push out the exhaust which translates to more power and efficiency.
flowmasters have great sound, and flow better than stock. however on higher hp engines they still tend to be a bit more restrictive than other brands. but for you V6 you should be fine.
don't expect huge gains. probably not even noticable gains in hp...just sound. if you really want to get the best gain replace the whole exhaust from the cat back. bigger pipes and better muffler will help make more power.
Old Dec 12, 2004 | 12:06 PM
yes im doing this from the cat back, ill be more excited if i get some more MPG gains outta the exhaust than the power lol, sorry gas is expensive.
Old Dec 12, 2004 | 01:06 PM
Capn Pete's Avatar
I wouldn't expect any increased mileage by changing the cat-back. Maybe in perfect conditions, but I know that with my Flowmaster, I get worse MPG now 'cause I peg it off the line all the time to hear the exhaust!! (it sounds really sweet).
A lot of guys claim that the Flowmaster doesn't actually "flow" all that well (compared to other aftermarket systems) but it's a step-up from stock. As well, I've only felt minimal SOTP gains.
Old Dec 12, 2004 | 03:01 PM
sir dyno's Avatar
I had a flowmaster and loved the sound but did notice it to be restrictive, meaning I felt less throttle response. If you want a baddass sound and no restiction get a Loudmouth from slp, you car will sound loud in your Camaro.
Old Dec 12, 2004 | 03:03 PM
sir dyno's Avatar
You will also see improved power gains.
Formula Steve
Sep 19, 2023 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Slayer
Aug 17, 2015 03:55 PM
alphaauto
Jul 26, 2015 04:40 PM
camaro02DK
Jul 5, 2015 09:24 AM
