floor console gauges
Old Apr 22, 2020 | 07:53 AM
tGodfrey99's Avatar
I've installed a 2010 Camaro interior in my 68. The console has the 4 gauge cluster. Does anyone know if I could wire them and use them. They are tied into a harness that would just plug into the new Camaro computer system.
Not a big deal as I have gauges already mounted into the dash but thought about hooking them up as well.
If not I can just remove them and put a tray in the place.
Thanks for any input
Old Apr 22, 2020 | 09:01 AM
DrewHMS97SS's Avatar
Re: floor console gauges
There are not many if any 5th gen owners around, so knowledge about the gauges will be limited at best; I'll shoot from the hip though. The gauges are just a visual representation of electrical data being sent from sensors or the ECU, thus with the right information being sent to to the gauge, it should work. That said, it will take a comfort with electrical diagrams, wiring, and troubleshooting.
If that didn't scare you off, in a perfect world, you could just install the 2010 sensors, then run proper cabling back to the gauges. I would start by trying to get a hold of a 2010 service manual to look up information about the gauges wiring, sensors and signalling information. If the ECU is sending the data to the gauges, it becomes more complex because you will need to find sensors that send the same data. Identify what is sending signal to the gauges, then go from there.
Old Apr 22, 2020 | 09:15 AM
tGodfrey99's Avatar
Thanks for the info. That is what I was thinking it might be more trouble than it is worth. Defiantly over my pay grade.
Might just remove it and put something else in that hole.
Old Apr 22, 2020 | 11:47 AM
I had seen in doing light hunting on your question some Auto meter gauges that had been made to fit in that location. You could then sell the stock gauge cluster to help pay for the new gauges
https://www.phastekperformance.com/2...o-pod-5286.htm
Old Apr 22, 2020 | 02:34 PM
tGodfrey99's Avatar
I had already bought the auto meter gauges mounted the the dash before I decided to use the newer style floor console. I just though I would hook them up if I could. They look good on the console.I may try to mount the Holley sniper touchscreen in place of the gauges.
Thanks for the help looking around
Old Apr 22, 2020 | 04:30 PM
That would look cool. You should share some pictures of your work!
94ZFBODY
Parts Wanted
Mar 4, 2010 12:22 PM
SSquid
Parts Wanted
Mar 22, 2004 01:21 AM
chasmanz28
Oct 22, 2003 04:42 PM
Bryan 94 Z28
Apr 25, 2003 07:36 PM
68SuperRam
Classic Engine Tech
Dec 9, 2002 01:13 AM
