Exhaust Rattling
Old Dec 20, 2006 | 08:14 AM
ChevEE's Avatar
Question Exhaust Rattling
I know what it is that is causing the rattling. From what I understand it is common on 4th gens to generate this rattle. I don't know the name of the piece. I think it is the tunnel brace... Anyways, can someone tell me what it's called please? Also, the larger question:what can I do to stop the rattle? Do I need it there? It is stock. It gets really annoying! Please help!
Old Dec 20, 2006 | 10:06 AM
Kraest's Avatar
Retired
Look under the car for something loose.
My 4th Gen exhaust never rattled.
BTW, this isn't a Tech question by far.
Old Dec 20, 2006 | 10:11 AM
teke184's Avatar
is it stock exhaust?
id be willing to bet it's a heat shield around the exhaust somewhere. you'll have to look. and that is as easy to fix as bending it out of the way.
and you should be able to see if the pipe is close to the cross brace.
Old Dec 20, 2006 | 10:25 AM
km9v's Avatar
Could be the rings around the O2 sensors.
Old Dec 20, 2006 | 10:39 AM
9T8W66's Avatar
I used little pieces of duct tape to solve that problem
Also if the Y pipe is banging the tunnel brace it may be a motor and or trans mount problem.
Old Dec 20, 2006 | 12:17 PM
SSpdDmon's Avatar
You could also move the tunnel brace down by putting a washer on the bolts between the brace and the floor pan. That should give you an extra 1/8 inch of clearance (depending on how thick of a washer you use). You'll need 4 of them.
On a stock car, this is more of a band-aid instead of a fix if the tunnel brace is truly the issue. As mentioned above, look for worn out motor mounts and loose heat shields as other potential rattling sources. Cat. converters may also rattle on their way out...
Old Dec 20, 2006 | 12:59 PM
IXLR894Z28's Avatar
The heat shields under the passenger seat toward the front on mine rattled, some pliers and a little bending solved the problem.
kxrawx
May 25, 2015 08:29 PM
May 15, 2015 10:43 AM
jayblev95
Dec 1, 2014 06:55 AM
squarehead
Nov 21, 2014 08:02 PM
Klypto
Jul 19, 2002 07:25 AM
