Exhaust Rattling
I know what it is that is causing the rattling. From what I understand it is common on 4th gens to generate this rattle. I don't know the name of the piece. I think it is the tunnel brace... Anyways, can someone tell me what it's called please? Also, the larger question:what can I do to stop the rattle? Do I need it there? It is stock. It gets really annoying! Please help!
is it stock exhaust?
id be willing to bet it's a heat shield around the exhaust somewhere. you'll have to look. and that is as easy to fix as bending it out of the way.
and you should be able to see if the pipe is close to the cross brace.
You could also move the tunnel brace down by putting a washer on the bolts between the brace and the floor pan. That should give you an extra 1/8 inch of clearance (depending on how thick of a washer you use). You'll need 4 of them.
On a stock car, this is more of a band-aid instead of a fix if the tunnel brace is truly the issue. As mentioned above, look for worn out motor mounts and loose heat shields as other potential rattling sources. Cat. converters may also rattle on their way out...
May 15, 2015 10:43 AM
squarehead
Nov 21, 2014 08:02 PM
