Engine Overheating at Low RPM's
Old Aug 29, 2007 | 12:30 PM
aaron1987's Avatar
As the title says, recently my z28 has started to overheat under low-rpm conditions, especially in 6th gear on the highway (where I first noticed it). Getting the rpm's up above 2.5k or so cools the engine down again without problem. If I come up to a stoplight or something that causes the rpm's to fall again the engine rapidly overheats within a matter of seconds. Thoughts?
Old Aug 29, 2007 | 02:56 PM
White96Z28's Avatar
Sounds like the water pump needs replaced. Maybe the WP drive is slipping and isn't turning the pump until you get the RPM's up. I would pull the pump and check for signs of the shaft slipping.
Old Aug 30, 2007 | 08:02 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Cracked head or headgasket. When engine is cool, remove radiator cap and start engine, if you see bubbles after a few minuets, you have one or the other.
SteveC
Old Aug 30, 2007 | 04:59 PM
aaron1987's Avatar
Will I need to bleed the air out of the system after running it with the cap off?
Old Aug 31, 2007 | 09:37 AM
SteveC's Avatar
No you won't.
SteveC
Old Sep 1, 2007 | 10:50 AM
aaron1987's Avatar
No bubbles, rather relieved.
Old Sep 2, 2007 | 08:14 PM
DeadMaul's Avatar
Sad. This is the same problem that i have with my camaro. I turn the engine on and wait a few minutes and the bubbles apperar. No much bubbles, just a litlle ones. How bad is?
AlaskaZ28
Jan 1, 2015 12:30 PM
AlaskaZ28
Dec 16, 2014 07:24 PM
AlaskaZ28
Dec 10, 2014 02:39 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
