Electronics experts- I need help with adapting LEDs for a 12v electrical system...
Old Oct 27, 2006 | 11:36 AM
FuryZ28's Avatar
Okay, I know you can't just straight-up wire an LED to a 12v electrical system. My question then is, what resistors (or other parts) will I need to solder onto the LEDs to make them compatible with a 12v electrical system??
Just FYI, I'm basically planning to replace my OE warning indicator lights with LEDs in my custom gauge cluster panel...
Old Oct 27, 2006 | 12:28 PM
Dave '97 Z28 M6's Avatar
IIRC LEDs are typically 2V and 10mA. That being the case, you'd need a resistor that would limit current to 10mA with a 10-12V drop (12-14V minus 2V). A 1Kohm to 1.2Kohm resistor would do the trick, in series with the LED.
Old Oct 27, 2006 | 12:42 PM
FuryZ28's Avatar
5 of my LEDs are rated @ 20mA (continuous forward current), and one is rated @ 30mA. What size resistor would I need for that, then? 500-ohm? 2k-ohm? I'm a novice when it comes to this sort of electrical stuff...
Old Oct 27, 2006 | 01:27 PM
T/A-Bob's Avatar
Those 20 and 30mA ratings are usually MAX continuous ratings at 25°C (room temperature). I personally would stick with Dave's recommendations and give yourself a margin of reliability.
Old Oct 27, 2006 | 01:54 PM
FuryZ28's Avatar
So, is it the higher the resistance, the brighter the LED, or the lower the resistance? If I went with the suggested range of resistors, would the 1.2k-ohm or 1k-ohm resistors yield the brighter LED display?
Old Oct 27, 2006 | 02:02 PM
T/A-Bob's Avatar
The lower the resistance, the brighter the LED will be. I'm not sure you could actually see a brightness difference between the 1K and 1.2K resistors, as they're pretty close in value ...??
Old Oct 27, 2006 | 02:25 PM
96 Z 28's Avatar
Some Additional Help
And probably a good place to purchase the bulbs themselves
Old Oct 27, 2006 | 03:58 PM
FuryZ28's Avatar
That's actually where I ordered mine from...
Old Oct 27, 2006 | 06:44 PM
oneslowz28's Avatar
a 1k ohm will be fine
Old Oct 28, 2006 | 01:35 PM
tom2's Avatar
I've bought several of these from Radio Shack with the resistor built in. Should be able to source them cheaper if you look around or if you need a couple, just go there.
Old Oct 28, 2006 | 08:03 PM
oneslowz28's Avatar
on ebay you can get like 100 of any color you want that are of the superbright style for like 3 bucks. and then you can get 1000 of the 1kohm resistors for a buck. i have every color in varring mah and use a 1k ohm resistor on them all and there bright as hell.
Old Oct 30, 2006 | 06:45 PM
FuryZ28's Avatar
Umm, please excuse my retardedness, but which side do I solder the resistor onto? The longer terminal, or the shorter one?
Old Oct 30, 2006 | 07:04 PM
T/A-Bob's Avatar
It doesn't matter.
Old Oct 30, 2006 | 10:07 PM
FuryZ28's Avatar
Hmm, I was under the impression it did...oh well, if I blow something up, I'll send you the bill...
Old Nov 1, 2006 | 06:36 AM
oneslowz28's Avatar
it does matter solder the resistor onto the long leg of the led. The resistor is there to reduce the voltage flowing into the led . If you solder it onto the short leg then it had no way of loweing the incomming voltage.
Rember these things.
  • long leg is always positive
  • short leg is always negative.
  • Resistor goes on either the positive feed wire or the long leg of the led.
  • It only can go on the positive feed wire when not running alot of leds as this could cause the resistor to heat enought to cause a fire.
  • A 1k ohm resistor is good for almost every led you find.
  • 1/4 watt and 12/watt resistors will both work.
