Electronics experts- I need help with adapting LEDs for a 12v electrical system...
Okay, I know you can't just straight-up wire an LED to a 12v electrical system. My question then is, what resistors (or other parts) will I need to solder onto the LEDs to make them compatible with a 12v electrical system??
Just FYI, I'm basically planning to replace my OE warning indicator lights with LEDs in my custom gauge cluster panel...
IIRC LEDs are typically 2V and 10mA. That being the case, you'd need a resistor that would limit current to 10mA with a 10-12V drop (12-14V minus 2V). A 1Kohm to 1.2Kohm resistor would do the trick, in series with the LED.
5 of my LEDs are rated @ 20mA (continuous forward current), and one is rated @ 30mA. What size resistor would I need for that, then? 500-ohm? 2k-ohm? I'm a novice when it comes to this sort of electrical stuff...
So, is it the higher the resistance, the brighter the LED, or the lower the resistance? If I went with the suggested range of resistors, would the 1.2k-ohm or 1k-ohm resistors yield the brighter LED display?
on ebay you can get like 100 of any color you want that are of the superbright style for like 3 bucks. and then you can get 1000 of the 1kohm resistors for a buck. i have every color in varring mah and use a 1k ohm resistor on them all and there bright as hell.
it does matter solder the resistor onto the long leg of the led. The resistor is there to reduce the voltage flowing into the led . If you solder it onto the short leg then it had no way of loweing the incomming voltage.
Rember these things.
- long leg is always positive
- short leg is always negative.
- Resistor goes on either the positive feed wire or the long leg of the led.
- It only can go on the positive feed wire when not running alot of leds as this could cause the resistor to heat enought to cause a fire.
- A 1k ohm resistor is good for almost every led you find.
- 1/4 watt and 12/watt resistors will both work.
