E-Brake Light comes on under hard braking?
Old Feb 16, 2005 | 11:56 PM
Formula_driva's Avatar
Exclamation E-Brake Light comes on under hard braking?
When im coming to a hard stop my E-brake light comes on on the dash, and sometimes stays on for awhile, if i tap the brakes a few times it tends to go away...whats up with that??? It only recently started doing this, and only under HARD braking....Anyone?
Old Feb 16, 2005 | 11:59 PM
Re: E-Brake Light comes on under hard braking?
The "BRAKE" light has two functions. One is to indicate the e-brake is on. The other is to indicate that the pressure switch in the distribution block on the side of the ABS unit has detected an incorrect pressure balance between the front and rear braking circuits. Could be a leak in one of the brakes, air in a line, or low fluid.
Old Feb 17, 2005 | 12:31 AM
Heatmaker's Avatar
Advanced Member
What this guy said...
although I'm not familiar with hte E-brake (M6) THe light will trigger on for the above mentioned reasons. Ocassional if there is air in your system the light will go on when you brake hard... not a bad time to check your system out... the BRAKE light is nothing to take lightly. A bad Master is causing mine ocassionally right now... could be a minor problem.. or a serious problem... but don't ignore it.
Old Feb 17, 2005 | 01:20 AM
thanks guys..My bird is an A4, so I obviously dont use the E brake much, Which also kind of worries me....Im thinkin about just takin it to midas or something and having it inspected....Im a n00b when it comes to brakes
Old Feb 17, 2005 | 01:28 AM
Don't Look Back's Avatar
Definetly have it checked out, but before you go anywhere just check you brake fluid level. My light was on and I was a little low on brake fluid.
Old Feb 17, 2005 | 01:43 AM
carlos64030's Avatar
Dude it really doesn't take much effort to pop the hood to check the level of the brake fluid.
Old Feb 17, 2005 | 01:48 AM
I was speaking in terms of having the actual brakes and lines inspected...Ive changed my waterpump...but I cant check my fluid levels
Don't be a dick
Old Feb 17, 2005 | 02:13 PM
Checked the fluid, its topped to where it should be
Old Feb 17, 2005 | 02:27 PM
ShawnMacAnanny's Avatar
Yeah the E-brake light comes on when low on fluid. My porsche 944 and 3000gt VR4 both did that. both were low on fluid.
Old Feb 17, 2005 | 05:08 PM
"White Knight"'s Avatar
Fluid could be sloshing forward and causing the sensor to go off. Like everyone else said check fluid. I'm confused though, does it say e-brake....I thought it just said BRAKE? I haven't been in my Camaro in months darn winter.
I aways seem to have the "low traction" light come on when i make a turn I wonder why...............lol
Old Feb 17, 2005 | 11:01 PM
it doesnt say e brake...i dont remember what it looks like lol...Some kind of brake light on the left under the Low Coolant Light
Old Feb 18, 2005 | 12:36 AM
Its not "fluid sloshing".... the switch located on the pressure block on the side of the ABS unit, and is activated by the difference in pressures between the front and rear braking circuits.
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
rwferguson43026
Feb 6, 2015 10:06 AM
squarehead
Jan 15, 2015 07:02 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
