E-Brake Cable issue
Old Nov 5, 2007 | 09:13 PM
Melee Penguin's Avatar
E-Brake Cable issue
Just parked the car. Set parking brake and.... noise.
I don't believe the cable snapped, do I just need to take apart the center console dealy?
Old Nov 6, 2007 | 05:27 AM
Are you saying that when you pulled the parking brake handle up, you heard a "snap", the handle came up, but the brake did not engage? If that's what happened, it could be a problem with the pawl in the ratchet that the handle operates. That was a common problem with the early 4th Gens, although I would have hoped they fixed it after 7 years of production.
Old Nov 6, 2007 | 02:31 PM
It actually sounded like a "clunk", but the handle gave way like the cable wasn't attached.
Funny thing is while parking it today is that it seems like it works
I'm going to test it on a graded hill later this evening.
Old Nov 11, 2007 | 07:08 PM
01Z's Avatar
01Z
It may be working on just one wheel. That's the story for my 95. Take a look and see if both brakes are coming on when you pull the brake up. My driver side parking brake was missing some small parts. I contacted Dal Slabaugh and got everything I needed as a retainer had departed at some point in the car's life and the little parts it held in place were deposited in some driveway or alongside the road.
Old Nov 14, 2007 | 11:52 PM
Fatdog2's Avatar
I had to replace both cables running the back brakes,because if you replace one(I was told),then,it might be uneven.Hope this helps.(The consol was the first place I looked also,it's not there).
DSMKilla
Jun 11, 2015 05:02 PM
BIGRIG
Parts Wanted
Apr 28, 2015 07:56 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
edman
Jan 25, 2015 02:41 PM
