Driveshaft
Old Apr 12, 2006 | 07:28 AM
ZL1modified's Avatar
Question Driveshaft
Anyone hear balance driveshafts?
If not do you know anyone local to me that will?
Fayette county, PA.
thank you
Last edited by ZL1modified; Apr 12, 2006 at 10:22 AM. Reason: Attention to my last post. it has a question.
Old Apr 12, 2006 | 09:41 AM
OBE1 95Z28's Avatar
Re: Driveshaft
I had my stock steel driveshaft "balanced" by a good shop using a magnetic pulse system; no improvement with the 70 mph vibration. Replaced the shaft with an aftermarket shaft (Denny's), no more vibration.
Old Apr 12, 2006 | 10:03 AM
97FormulaWS-6's Avatar
Re: Driveshaft
No idea where that is in PA, but Denny's does all my DS work, he's up here in Buffalo, NY.
Old Apr 12, 2006 | 10:17 AM
Arrow Re: Driveshaft
Thanks for the replies.
there is actually a place 20 mins. away.
its called fayette welding, but they do drive shafts.
i bought my aluminum drive shaft used but it still vibrates, however i used the same u-joint.
is it possible my drive shaft is out of balance or could it be the u-joint?
it starts vibrating at 70 and quits at around 90. it's so annoying!!
(when doing 70) i let off the gas it does not vibrate. as soon as i touch the pedal it starts.
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
