drivers door sagging about 1/2 " need help
Old Jun 20, 2005 | 10:15 PM
oneslowz28's Avatar
the 94 is getting painted tomorrow and i just replaced both doors due to them cracking where the sms meets the fiberglass. once i got the doors installed i noticed that the bolt above the latch ( the one that slides into the top hole on the door) scrubs going in just a bit i have to lift the door up about 1/2" to make it not scrub. i would like to fix this before its painted becuse why ruin a 3k$ paint job. any sujjestions on what it may be. could it be the pins and the bushings inside the hinges?
Old Jun 20, 2005 | 10:22 PM
IROC-T's Avatar
Re: drivers door sagging about 1/2 " need help
If GM used the same hinges/and,or pins on the 4th gen. as they did on the 3rd gen. it's diffenate "YES". Most likely the bottom one. Do a search both here and TGO and you'll find the part number also.
BLK1997Z28
May 2, 2015 01:26 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
