driver side window problems
Old Jan 1, 2009 | 11:44 AM
freethrowchamp's Avatar
when the door is open and i feel the glass its really wobly. which pisses me off. but any ways when i go to roll it up it gets like 1/2 to 3/4 up it takes a sudden right turn. like a lot. i have to push on it to keep it on track. then i have to play with it to get the right height. cause the damn thing will go up to high and catch on the t-top and wont shut. if i get the height right then i have either a leak up front of the window or the back. this problem really pisses me off. does any body know how to fix it?
Old Jan 1, 2009 | 11:49 AM
i forgot
oh by the way i have a 94 camaro z28 with t-tops. ive pulled the door panel off and the little metal thing on the top left moves way to much.
Old Jan 1, 2009 | 03:07 PM
jhthornley's Avatar
best place I could send you to look for info would be shbox.com... (Rob) His site is full of good stuff and I know window motors etc are shown on there.. JT
Old Jan 1, 2009 | 09:53 PM
Counted Out's Avatar
Tighten it. My window was way off track and it turned out my stabilizer was broken so it was also scratching the hell out of my tint. Even after I put the new stabilizer on I had to adjust it to make it perfect.
Old Jan 1, 2009 | 11:58 PM
TBSPW's Avatar
yeah i have the same problem but im just letting my dealer deal with it cuz im just too lazy i guess.
Old Jan 2, 2009 | 09:52 AM
trippin holyman's Avatar
i had the same problem. ending up replacing my window with a junkyard window. apparently, there is a rivet that wear out and this rivet helps keep the window on track. so check that out i guess.
Old Jan 6, 2009 | 03:31 PM
97QuasarBlue3.8's Avatar
Bingo. It can happen from closing the door by pushing on the glass over a number of years--or just too hard, even if the car is relatively newer. Once you get it fixed, if you don't already, close the door by pushing on the actual door and not the glass.
karnykamaro
Feb 2, 2015 01:37 PM
cmdeshon
Parts Wanted
Dec 16, 2014 07:58 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
