Need Help PLease ! Replacing Starter on 95 camaro 3.4l
well i removed the starter . which one of the exhast y pipes runes right under it and now laying on the exhast cant get it out !!!!
then...
i removed the bell housing pan thinking i could get out the starter but no.......
the transmission lines are in the way !~!
how do get this thing out ? why whould gm do this on a high replacment rate like a starter ?????
please help me out iam going nuts . iam not removing the exhaust , and those transmission lines look like a pita
then...
I was able to get mine out on my '97 Z28 M6. I believe on LT1 auto cars you have to remove the y pipe, so I'm assuming you will to. It was a PITA to get the starter out without removing the y pipe. I'd pick up some PB Blaster and unbolt your Y pipe.
I just replaced the starter on my 1994 Z28 with the 5.7 and did not remove the Y-pipe. I simply removed the bell housing and unhooked the trans lines at the radiator and the return line next to it then unhooked the bracket holding them to the engine. When I did this the trans lines moved out of the way with a little tug.
Zomie
Jul 22, 2002 03:34 AM
