door skin coming loose
what kind of adhesive would anyone recommend for a oem equivelant to reapply the door skin by the handle. Not sure if someone tried to break into my car, or was just a poor job of assembly. thanks for any help.
Re: door skin coming loose
I've looked this up and I'm just taking mine to a body shop and making sure it's done right because everyone says that most if not all of the stuff you buy at the store doesn't work.
Originally Posted by dcatch01
I sure wished it was the drivers door. I would remove the whole skin and repair my window motor while I was at it. Just my luck passenger side motor works just fine.
Originally Posted by Dave89IROC
structural adhesive is what is needed
). Thank you for any insight you might have. :nice:
Originally Posted by user name
That sounds more like it. Any idea where one might procure this (an actual source and/or brand, for us non-engineer types.
). Thank you for any insight you might have. :nice:http://www.sjdiscounttools.com/sem39337.html
http://www.lord.com/Default.aspx?tabid=1193
check with a local painters supply and see if they have some type, there are many different brands, the 2 part is best, but the 1 part is fine, especially since the skin hasn't come all the way off(1 part/single stage has a slightly longer cure time)
heres some
FWIW, in case it helps folks, I had tried a two part epoxy for plastics originally. Application was an issue (getting the epoxy into the crevice) but it was clean in there, etc and applied decently. It held for a couple weeks maybe, before letting go again (upper right hand corner of the door, adjacent the exterior door handle).
Thank you again for the info and links.
