doing away with abs question
Old Apr 6, 2008 | 03:38 AM
ta97383stroker's Avatar
i been thinking of going away with abs on my 97 formula. i was woundering will that mess any thing up or will my car not shift right.someone told they think the transmission works with the abs unit on when it is supossed to shift. is this true or not please help
Old Apr 6, 2008 | 05:09 AM
95camaroinok's Avatar
If you just want to disable the system, you can just pull the fuse for it. It will default into regular brake system operation. It wont mess with your trans. They are thinking accellerated slip regulation, which still doesnt really have anything to do with the trans itelf, but probably what they were thinking of. If you want to remove the entire system you can do that as well, but will have to route some new brake lines. Try driving with just the fuse out first to see if you really want to do away with it. I used to hate ABS before I got my Camaro, it has actually saved my a$$ a few times in this car. Having said that,
*** I take no responsibility if you slide into somebody after disabling your ABS or wreck your car in any other way!!!***
Use your own judgement, if your not used to a non ABS car then find somewhere to drive that thing where you cant hurt yourself, somebody else, or your car, and get used to how it will drive/stop.
Now, having said that, if you know what your doing and HAVE driven cars without abs and know how to actually drive a car *think 60s-70s model boats with no power steering/brakes* than I mean no disrespect with the warning of how different it is, etc. Good luck and have fun.
Old Apr 7, 2008 | 12:25 AM
im not going to be driving the car in rain its going to be pretty much down the strip and nice sunny days around town thanks for the info
Old Apr 7, 2008 | 02:13 AM
GreasyB's Avatar
Are you wanting to delete the unit itself or just disable it?
Old Apr 7, 2008 | 12:18 PM
ive already ripped it out and going to try a porpurtion valve off a oldder camaro
Old Apr 7, 2008 | 01:05 PM
You can get all the parts required for an ABS delete, including the proportioning valve, line lock solenoid and pre-formed lines:
http://www.sjmmanufacturing.com/cam_brk_lt1.html#
Old Apr 8, 2008 | 01:30 AM
Thank you Injuneer, I knew the kits were out there, was just out of it a little when I posted and didnt think about that. Word of advice--- ALWAYS listen to Injuneer
jj_burchiel
Mar 21, 2015 12:51 AM
dluna333
15
Mar 13, 2015 12:30 PM
dluna333
Parts Wanted
Mar 6, 2015 07:11 AM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
