Does anyone know what goes here?
Old 08-22-2013, 04:47 PM
  #16
Re: Does anyone know what goes here?
95 harness - 94 will be similar, courtesy of Shoebox:
1995 Z28 A4 Engine Harness
Injuneer is offline
Old 08-22-2013, 07:00 PM
  #17
Stephen68's Avatar
Originally Posted by GaryDoug
According to the service manual there should be 4 wires: light blue/black, light blue/white, light green/black, and light green/white.
GaryDoug, i found those wires but for some reason the last (IDIOT) owner cut the plug off of them....is it possible to buy just the plugin?..
Stephen68 is offline
Old 08-22-2013, 07:01 PM
  #18
Stephen68's Avatar
Many thanks Injuneer....it might be best to just replace the harness instead of trying to patch it...i dont like half ****n things lol....
Old 08-22-2013, 07:04 PM
  #19
Stephen68's Avatar
Just curious...does anyone know of a diagram that shows all the sensor locations? I also noticed that my O2 sensors are not plugged in lol...this is turning out to be a real project....
Old 08-22-2013, 07:52 PM
  #20
Shoebox has pictures and diagrams of everything. You need to spend some time going through his website. You'll learn a lot more that way.
Injuneer is offline
Old 08-22-2013, 08:30 PM
  #21
Stephen68's Avatar
Do u have a link to his site Injuneer? Thanks!
Old 08-23-2013, 08:01 AM
  #22
I can't believe anyone owns one of these cars and hasn't already been there. It is an unbelievable resource, and has been there for 15 years. Plus, Rob/Shoebox has links in his signature.
4th Gen LT1 F-Body Tech Aids
Injuneer is offline
Old 08-24-2013, 01:02 PM
  #23
Specifically, this page. Most of the items have clickable links to pictures of them. Just hover over the item with your mouse, then click.
shoebox is offline
Old 08-24-2013, 05:58 PM
  #24
Prominent Member
GaryDoug's Avatar
Location: Born on the Florida West Coast, now where can I retire?
I have no real idea. I tried some sources, without any success. You can use this link to download a complete service manual for your car. Be advised however, there is an error in the component location diagram for the IAC valve. Evidently it shows the 93 instead. The 96 manual seems to show the correct view. The IAC connector end view looks correct.
http://www.mediafire.com/?40mfgeoe4ctti
GaryDoug is offline
Old 08-24-2013, 06:20 PM
  #25
The 93 and 94 IAC valve location is the same, but the part # and harness connectors are different.
Injuneer is offline
Old 08-24-2013, 08:18 PM
  #26
Prominent Member
GaryDoug's Avatar
The location is the same but the location view diagram is not. It shows a square (2x2) 4-way connector instead of the correct rectangular (1x4) connector.
GaryDoug is offline
Old 08-24-2013, 09:48 PM
  #27
Prominent Member
GaryDoug's Avatar
This may be a real long shot: Using the 94 manual and the company where I get Delphi connectors, I could not match the connector number with their stock. But I could find the connector for a 96 that matches the 96 manual part number. If anyone here knows if the 96 connector would fit the 94 valve, this might be the correct part.
The source is:
For 1996:
pins= 12124075-L Delphi Connection Systems | Mouser
body= 12162190 Delphi Connection Systems | Mouser
Here is a body that is close to the 94 part number (12110188) but not exact: 12162188 Delphi Connection Systems | Mouser
You can browse the connectors, but do not trust the images to be accurate. Also, the 94 manual says it a Metri-pack type 150, not the type 150.2 found in the 96 manual and in the links above.
Edit: The links also point to a datasheet on the Delphi web site... but you have to re-enter the part number after getting to Delphi search. See the Documents tab and the 2d drawing (.tif) file for complete details including an options table.
GaryDoug is offline
Old 08-25-2013, 10:24 AM
  #28
To add to the confusion - According to Shoebox's parts list, 94/95 with RPO KC4 (oil cooler???) have one part # for the IAC valve, and 95 W/out KC4), 96-97 have a different part # for the IAC valve.
Why would an auxilliary oil cooler change the IAC part #? Could it possibly have been with RPO "K34" (cruise control) that determines the IAC valve?
My 94 (very late production number, with KC4) has the in-line 4-pin connector. I just can't get to it (still recovering from shoulder surgery) to pull it off the sensor and check.
Injuneer is offline
Old 08-25-2013, 07:44 PM
  #29
Prominent Member
GaryDoug's Avatar
Here it is. Too bad I did not remember this source first:
EFI Connection, LLC - Item Details
They have the other style also (2x2).
GaryDoug is offline
Old 08-26-2013, 02:23 PM
  #30
Stephen68's Avatar
I have been there Injuneer, i just forgot to bookmark it for later reference.
