Disable Factory Car Alarm
Old May 4, 2008 | 01:56 PM
ping0317's Avatar
Exclamation Disable Factory Car Alarm
Anyone has an advice to disable the car alarm? I have a 94 firebird formula and I believe that car alarm is draining my battery.... Please help
Need to disable that alarm
Old May 4, 2008 | 08:45 PM
ss.slp.ls1's Avatar
I would read through this:
http://shbox.com/1/pass_key.html
Old May 29, 2008 | 07:01 PM
Oxygen454's Avatar
Our of ceriousity, how do you know its your alarm that is draining your battery? In the process of removing your alarm you might find the problem unless its with in the alarm module. Try disabling the alarm and see if the battery still drains with the alarm disconnected.
Old May 29, 2008 | 07:34 PM
Green96Z's Avatar
Most likely it's something that you did. Unless you were messing around with the alarm wiring, your culprit is an issue you accidentally created. So go back and look at some of your recent work and make sure all your grounds and connections are good.
cmdeshon
Dec 27, 2014 10:06 AM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
NAVY99
Oct 3, 2002 03:47 PM
dreamer1q
Jul 24, 2002 04:39 PM
