Disable automatic light turn on
Re: Disable automatic light turn on
REAL easy
Do you know where the light sensor is on top of the dash? Well, pop up that big plastic dash piece (it's got I think 4 clips holding it down, and you pry it up from the back edge). Find the light sensor neer the middle, and it should have 2 wires going to it. Now you've got 2 options: one is you can cut the wires, and join them together on the car side, which by-passes the sensor. The other option that some guys do is to unplug the sensor, and use a wire or even a paper clip to link the 2 terminals together (same effect as joining the wires). Tape it all up, put the dash back down, and enjoy having control over your lights!!
.Do you know where the light sensor is on top of the dash? Well, pop up that big plastic dash piece (it's got I think 4 clips holding it down, and you pry it up from the back edge). Find the light sensor neer the middle, and it should have 2 wires going to it. Now you've got 2 options: one is you can cut the wires, and join them together on the car side, which by-passes the sensor. The other option that some guys do is to unplug the sensor, and use a wire or even a paper clip to link the 2 terminals together (same effect as joining the wires). Tape it all up, put the dash back down, and enjoy having control over your lights!!
Here is a link you can read. http://www.fasidemedia.com/personal/...eautolamps.htm
squarehead
Jan 15, 2015 07:02 PM
Jul 4, 2005 05:00 PM
formula79
26
Aug 5, 2002 12:21 PM
