died while driving?
died while driving?
i was on the highway doin a steady 75 mph, then all of a sudden the car just shut down and wouldn't start back up. when the car is in the on position you can hear the fuel pump kick on so i think it's gettin fuel. Would it be the ignition modual? or the coil?
Thank you
Andrew
Thank you
Andrew
Might also be a problem with the resistor in your ignition key if you've got one that is
Sometimes they stop working or stop working right . . . not sure how you'd test for that other than replacing the ignition key . . . or do you have another key that you could try?
The battery was/is still charged. When i was on the side of the road it wouldn't start back up, it'd crank over but not fire, the radio and all the gauges would still come on. i haven't had it scanned for codes yet. And i haven't checked for fuel pressure yet. Thanks
Well i also failed to mention that i had the car scanned two weeks ago when a cooling line dripped coolant all over everything and i had a new opti installed. but nothing showed up but a crankshaft sensor. So i maybe put 30 miles on the car since then, and it dies when i try to make a 225 mile trip. So maybe i fried the ignition modual when the opti went out? idk though.
