did something stupid while replacing window motor
Old Dec 30, 2006 | 06:24 PM
ViperXx's Avatar
Hi all,
I recently had my window motor go out, so I purchased a new one, and finally got around to installing it tonight. Well, it's been about 4 years since I last replaced one (I used to do a lot of repairs to my own cars).
Any how, I couldn't find anything in my book on it and I did most everything from memory until I got to the part of drilling the rivets. I didn't realize until it was too late that I drilled the wrong rivets. So, now I have my regulator and my window motor out (however, I only have screws for my new window motor).
So, I'm let with, do I go buy a new regulator just to get the screws (lol!) or does anyone know what size screws I need, or any suggestions?
I realized after I got the regulator out that I needed to drill through the door panel to remove the rivets from the window motor/regular, but now its too late.
Thanks in advance
Old Dec 30, 2006 | 07:46 PM
razor02097's Avatar
hitch a ride over to a local hardware store and see if they might have some sheet metal screws the size you need
Old Dec 30, 2006 | 08:39 PM
ACE1252's Avatar
Rivets replaced with 1/4" bolts and Nylocks.
http://web.camaross.com/forums/showthread.php?t=473408
Pics and Shoebox's site
http://web.camaross.com/forums/showthread.php?t=469384
Old Dec 30, 2006 | 09:54 PM
U240's Avatar
I did basically the same thing I just took my bolts for the window to the hardware store and got the same size , I also got washers for both sides and I used locktight on them just to be safe .Its been a couple of years now with no problems
Old Dec 31, 2006 | 07:38 AM
ViperXx's Avatar
thanks for the suggestions guys, going to drive over to the hardware store shortly (hope it doesn't rain)
Old Dec 31, 2006 | 05:09 PM
ViperXx's Avatar
Ok, I spent the better part of the morning trying to get the wheels back on the track (perhaps I forgot to mention I tried to pull the whole assembly out and the wheels came off the tracks).
I now have everything lined back up and ready to go, however, I went through trying to use the same screws that came with the window motor (got some washers), and couldn't get the nut in.
So, went down to the automotive supply stores (first Advance Auto Parts), showed them what I had for a rivet before, and they handed me a rivet gun and a package of I think 3/16 rivets. I told them this looked to be too small, and they assured me it would work ($11 there).
I go home, and behold, its too small I think I need 1/2 rivets, so I go around to all of the automative supply stores (Autozone, Napa, Advance) and even hit others (Wal-Mart, Home Depot, Lowes), and nobody had the rivets I need. I finally get told that the dealership will have the rivets I need.
I hope the dealership is open tomorrow. Does anyone know if they even carry a thing like rivets? Guy at the auto parts store said "If it's on your car, they'll carry it).
Old Dec 31, 2006 | 05:18 PM
JaysGone's Avatar
been a few years for me too. We used to use 1/4 or 9/32 rivets. They used a rivet gun called a "Big Daddy" riveter. You might try 1/4 -20 nuts and bolts they always worked when we ran out of rivets
Old Dec 31, 2006 | 06:40 PM
RE AND CHERYL's Avatar
Don't waste your money on the rivets. Nuts and bolts will do fine. That's usually what the dealer uses anyway.
Re'
Old Jan 1, 2007 | 07:20 PM
jbird's Avatar
They're right, nuts and bolts should work fine. If you want it riveted back in just because, leave you're door panel off and take it to a local gm dealership bodyshop or service department. They normally have parts trays stacked full of things like rivets, plastic rivets, clips, etc. They'll probably rivet it back in for you for a few bucks, or at least my bodyshop will. But, as stated above, it's fine to use nuts and bolts, just be sure they're tight.
warmeck
Feb 2, 2015 12:44 AM
capebuf
Jan 13, 2015 07:22 PM
Jazsun
Dec 29, 2014 12:14 PM
97 RedSS
Jun 10, 2003 07:58 PM
