dial indicator
Old Jul 15, 2006 | 12:17 PM
95LT1conv's Avatar
dial indicator
does anyone know how to use these to check valve lift? all the ones ive seen have pointer tips on them which confuses me about haow to get on a valve spring
Old Jul 15, 2006 | 11:31 PM
95LT1conv's Avatar
Re: dial indicator
no one can help me with this?
Old Jul 15, 2006 | 11:44 PM
95LT1conv's Avatar
Re: dial indicator
shoebox, is there any info on your site about using thees things?
Old Jul 16, 2006 | 07:41 AM
Dave89IROC's Avatar
Re: dial indicator
what are you trying to do?
measure valve lift, lube lift, spring bind, ect.?
Old Jul 16, 2006 | 09:25 AM
95LT1conv's Avatar
Re: dial indicator
it says specifically valve lift in my first post
Old Jul 16, 2006 | 09:27 AM
Dave89IROC's Avatar
Re: dial indicator
well, to measure valve lift with a dial indicator, you need a solid lifter and a checking spring
however, if you use the dial indicator on the lifter body, and then multiply by the rocker arm ratio, you get valve lift
Old Jul 16, 2006 | 09:53 AM
95LT1conv's Avatar
Re: dial indicator
so in other words i would have to pull the heads off. right now im just not sure whats in the motor. i did a valve adjustment a little while back and noticed some hand written numbers on the inside of the heads. dont know what they mean and dont want to waste money on heads or cam if i dont need them
Old Jul 16, 2006 | 10:04 AM
Dave89IROC's Avatar
Re: dial indicator
you can get a good idea on lobe lift if you just pull the rockers and check the pushrod, but this might not be as accurate as the lifter body, if you do this, mount the indicator vertical above the pushrod(no angle if at all possible)
then multiply by your rocker arm ratio(1.5, 1.6, ect.)
Old Jul 16, 2006 | 10:09 AM
95LT1conv's Avatar
Re: dial indicator
thanks for answering
RUENUF
Mar 13, 2016 03:37 PM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
ZXXVIII
Sep 1, 2015 10:13 PM
RallyRed701/2
Jul 27, 2015 02:55 PM
