Diagram
Old Feb 16, 2011 | 06:33 PM
lyn34's Avatar
Diagram
Hi camaro community. Have seen this diagram while browsing the net. Is this diagram is correct for door lock switch? Or does it seems to be incomplete? Any thoughts?
Thanks mate,
Lyn
Old Feb 17, 2011 | 05:21 AM
Re: Diagram
Whatis the year and model of the vehicle you are trying to add this to?
Old Feb 17, 2011 | 07:13 AM
Chevyssoccer's Avatar
Re: Diagram
It is correct and complete, but like injuneer said, Is this for aftermarket power door locks, is the signal a (-)? If not they have to be wired differently. The two relays work together. while you push the unlock button one relay is energized and the other reads ground. When you push lock the relays reverse.
This is the same way the power window rewire works when you use the door buttons to control relays with heavier dedicated power wires.
Aaront810
Aug 29, 2020 09:34 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
STEPHEN JOHNSON
Sep 7, 2015 02:28 PM
TGGodfrey
Aug 18, 2015 06:08 PM
4586
Aug 18, 2015 07:08 AM
