dash lights dont work - need help!
Old Apr 30, 2007 | 01:18 AM
thepavementpounder's Avatar
This problem has becoming more and more of a pain in the @$$, and with inspection coming up soon, I dont want to fail for something stupid like this, not to mention I need to estimate my speed at all times when its dark.
SO heres the deal: The lights on the dash and the radio dont work, like if you turn the dimmer wheel all the way down. Culprit: dimmer fuse. I have replaced it numerous times only for it to blow again, and it is now to the point where it blows immediately. I dont know what is on the same circuit or what, but I am guessing it is something like a bad ground?? (but I am not sure where this would ground anyways, the ones under the hood look fine) I really suck with electrical stuff, so any input is greatly appreciated.
Thanks in advance.
Old Apr 30, 2007 | 05:17 AM
There's a list in the Owner's Manual showing what's on each fuse. If you don't have a manual, Shoebox has a link to online copies on his website.
Old May 1, 2007 | 01:34 PM
Z28SORR's Avatar
The dash lights are fairly reliable, I would pull the radio and remove the connectors from the back and try the fuse again. At least this would isolate between the dash and radio.
Old May 1, 2007 | 06:50 PM
I installed an MP3 player that used the aux feature of the head unit (the head unit was from a gm truck or something). I grounded that to the bracket that the front of the console bolts to, below the radio area. Would this affect it?
Old May 1, 2007 | 07:30 PM
Plague's Avatar
It could if the grounds are not the same. Why not remove it for awhile and see what happens.
mr28
Apr 20, 2016 05:44 PM
squarehead
Jan 15, 2015 07:02 PM
fpete1992
Dec 11, 2014 03:51 PM
siguy
Nov 27, 2014 10:07 AM
mr28
Nov 23, 2014 11:11 AM
