Crud build up behind waterpump 94 z28
Old 08-29-2015, 05:09 PM
reww86's Avatar
I am in the process of changing my OPTI, and while removing my water pump to get to the OPTI I noticed the whole side of my engine has a massive build up of crud behind the waterpump, and all over the OPTI. Is this normal? If not what could be the issue? I really don't think my head gaskets are gone, no smoke or anything..no rad fluid in oil or other way around.
reww86 is offline
Old 08-29-2015, 05:25 PM
Re: Crud build up behind waterpump 94 z28
Probably timing cover round seals. Good time to replace them.
shoebox is offline
Old 08-29-2015, 05:36 PM
That wouldn't be caused by a head gasket leak. It's oil from the front seals as Rob indicates.
Injuneer is offline
Old 08-29-2015, 06:04 PM
reww86's Avatar
Awesome, thank you for the quick reply. I guess I'll be replacing some seals too!
reww86 is offline
10-31-2016 11:09 AM
Moshbmx1
01-20-2015 03:27 PM
AlaskaZ28
01-01-2015 12:30 PM
Bearmans
12-03-2014 05:28 AM
Quick Reply: Crud build up behind waterpump 94 z28
