crank position sensor
Old Oct 1, 2011 | 02:00 PM
aknight_sa's Avatar
i was getting code P0336 code on my 97 Camaro (LT1) with code P0303... i changed the Crank position sensor as i had a new one already... the issue is after changing it the rpm goes up and stays around 1500 RPM while in Park or Neutral gears, goes around 800-900RPM in Drive or Reverse..
why would the RPM go up after changing the crankshaft position sensor?
thanks
Old Oct 1, 2011 | 02:09 PM
Re: crank position sensor
Is it possible you knocked the coolant temp sensor connector off the coolant temp sensor in the water pump housing?
Old Oct 1, 2011 | 02:54 PM
aknight_sa's Avatar
i dont really think so, would the coolant temp sensor do that? because i was getting code P0118 as well
just in case another code i did get was P0400
all codes were before changing the crank sensor
Old Oct 1, 2011 | 03:18 PM
The PCM elevates the idle RPM based on low coolant temp. It will also cause the engine to run extremely rich, because the PCM uses a richer A/F ratio when the coolant is cold.
Have you rechecked the codes since you replaced the CKP sensor?
Old Oct 1, 2011 | 03:28 PM
aknight_sa's Avatar
after replacing the CKP i reset the codes and p0336 showed immediatly
Old Oct 1, 2011 | 07:12 PM
There are some instances of problems with the Opti causing that code to set. The CKP is only used for misfire detection. But the PCM has to compare the rotational velocity of the CKP to the know RPM of the engine, and the PCM gets the RPM info from the Opti.
Did you check the harness wires for the CKP?
Old Oct 2, 2011 | 03:18 PM
aknight_sa's Avatar
drove it today to work and back... the only code showing now is the p0336.
i believe i should check the electrical connections
HectorM52
Jul 30, 2017 11:46 AM
VF-124
Mar 16, 2015 08:14 PM
eazyZ
Mar 1, 2015 07:12 AM
Queens94z28
Dec 20, 2014 09:11 PM
Injuneer
Dec 15, 2014 09:36 AM
