Courtesy Fuse
Old May 25, 2005 | 06:03 PM
SWINGRRR's Avatar
Courtesy Fuse
What all is controlled by this. I have a Haynes, but cant find it. I kinda need to know now.
Old May 25, 2005 | 06:25 PM
Re: Courtesy Fuse
You negect to provide any info about the car , but your owner's manual will tell you.
Old May 25, 2005 | 06:46 PM
SWINGRRR's Avatar
Re: Courtesy Fuse
Its a 93.
My battery keeps dying. I tried the voltmeter but it only goes out to .0 amps. I put my test light in-line with the negative battery cable and the terminal. It came on. All doors were closed, and the key was not in.
I start pulling fuses and when I pulled #8, the courtsy fuse. the light dimmed slightly. I closed the door and the light went off.
When I jumped the car earlier and hit it with the voltmeter, it is charging at 13v.
Old May 25, 2005 | 06:53 PM
SWINGRRR's Avatar
Re: Courtesy Fuse
Of all the most stupid things, it is the light switch in the center console.
I came across the console light and when I pushed the switch down the light flickered. I closed the door and pushed the switch down and the light went out. Hooked everything back up, cut the wires to the switch and the light stays out.
Jeff1904
Jun 5, 2016 05:00 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
z28cam1993
Sep 9, 2015 04:08 AM
RUNMYTA
Jul 15, 2015 07:50 PM
