Cooling question
Old Nov 4, 2014 | 09:44 PM
brentbrowning01's Avatar
Cooling question
Hey guys! Quick question(s). I drove my 95 Z28 from Georgia to Tennessee this past weekend. Everything was fine until I would exit off the interstate to refuel or eat. My temp gauge would settle between the first and midway tick while on the interstate but when I would exit off the temp would spike up to almost touching the RED HOT mark. Once I'd get going around 35-45 mph it would come back down to just below the halfway mark. My fans aren't coming on either. I've checked all coolant levels and everything is fine. It has me stumped. I've been thinking about changing out the thermostat but I'm not sure that's the problem. I HOPE it's not the water pump... Any thoughts?
Old Nov 5, 2014 | 07:32 AM
Re: Cooling question
You already said your fans are not coming on. You need to find out why. I'd want to know what temperature the PCM is seeing (it uses a different sensor from the gauge). You'll need to be able to scan it for that info.
4th Gen LT1 F-body Tech Articles
Old Nov 5, 2014 | 12:50 PM
What kind of scanner do I need?
Old Nov 5, 2014 | 02:35 PM
https://www.camaroz28.com/forums/com...95-lt1-874306/
Old Nov 5, 2014 | 06:38 PM
I'm sure it's a great app but it doesn't seem to work with windows 8...
Old Nov 5, 2014 | 07:44 PM
I'll let the author respond... he's a member.
Old Nov 5, 2014 | 09:31 PM
GaryDoug's Avatar
Prominent Member
It works on my convertible HP notebook with Win 8.1. It could be that your security level is set too high. If there any error message? My app is not digitally signed because that costs a bunch of money; that could be an issue for you.
See post #23 in the link Fred posted.
Old Nov 5, 2014 | 10:09 PM
Thank you GaryDoug! I'll check my settings. Thank you so much for making such a program and making it FREE! Injuneer and Shoebox thanks for your always helpful advice as well. I appreciate you guys!
Noenav
Mar 1, 2019 07:38 AM
grgguy
17
Feb 23, 2015 07:57 PM
ChrisFrez
Jan 18, 2015 08:05 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
