Cooling question
Cooling question
Hey guys! Quick question(s). I drove my 95 Z28 from Georgia to Tennessee this past weekend. Everything was fine until I would exit off the interstate to refuel or eat. My temp gauge would settle between the first and midway tick while on the interstate but when I would exit off the temp would spike up to almost touching the RED HOT mark. Once I'd get going around 35-45 mph it would come back down to just below the halfway mark. My fans aren't coming on either. I've checked all coolant levels and everything is fine. It has me stumped. I've been thinking about changing out the thermostat but I'm not sure that's the problem. I HOPE it's not the water pump... Any thoughts?
Re: Cooling question
You already said your fans are not coming on. You need to find out why. I'd want to know what temperature the PCM is seeing (it uses a different sensor from the gauge). You'll need to be able to scan it for that info.
4th Gen LT1 F-body Tech Articles
Prominent Member
See post #23 in the link Fred posted.
Thank you GaryDoug! I'll check my settings. Thank you so much for making such a program and making it FREE! Injuneer and Shoebox thanks for your always helpful advice as well. I appreciate you guys!
ChrisFrez
Jan 18, 2015 08:05 AM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
