Cooling and Heating hose
Re: Cooling and Heating hose
As noted in response to your previous post, you need to point out the specific part #’s from the above diagram for the parts you need.
Also, Shoebox recommended you consider replacing the comple heater hose system.
https://www.camaroz28.com/forums/lt1...r-hose-888936/
Are you sure you have the correct diagram? Your screen name seems to indicate you may have an SS. That would be the 95-97 diagram I linked in your earlier post.
OK. Then that's the wrong diagram for your car. I pointed out the differences in the other post. Use this diagram:
http://shbox.com/1/heater_hoses.jpg
Then tell us the specific parts you need,,,, example - #12, #14, etc.
Or.... here's the complete assembly, as Shoebox recommends:
https://www.stockwiseauto.com/acdelc...YaAi2AEALw_wcB
You may be able to find it cheaper, using the part # in a search.
