Cooling fans restricting air flow 45 MPH and up !!!!
Ok I had my PCM tuned my ION@MADZ28 . Well i chose to have the cooling fans come on at a lower temp than stock . Well this is my problem ....
The car runs cool and just fine in town driving (anything 40 mph or below) . When the car is moving 41 MPH and up while the cooling fans are still on they (cooling fans) become a restriction to airflow causing the car to heat up more than usual . My Cooling fans are staying on at 41 mph and above because the PCM sees the coolant temp not dropping (caused by the fans on at highway speeds) . I need the fans to turn off while at highway speeds so the car doesnt heat up . Am I explaing myself correctly ? cuz my point is If the Cooling fans are on high at highway speeds they become a restriction to airflow getting to the radiator to cool the car down . |
You think theyre that much of a restriction? They're behind the radiator?
-b |
Yes because the fans can pull only so many cfm's while on the high
setting . There is more cfm's of air coming into your radiator at highway speeds than the fans can pull through . so the air doesnt get pulled through the radiator cuz the fans are acting like a wall keeping fresh air from getting through . |
How do you "know" they are a restriction? Maybe you have an air dam problem. That would be more common.
Originally Posted by AZ2ENVY
(Post 4743215)
I don't think the fans are your prob., be sure the AC condenser and front of radiator are not dirty, a plastic ice bag got me on the interstate once, don't take much to get too hot. Danny Mc
Originally Posted by shoebox
(Post 4743243)
see a temp difference when the fans arent on at highway speeds . |
Hey do you guys think this could be contributing to my highway
cooling issues ??? http://i2.photobucket.com/albums/y10...9698679004.jpg http://i2.photobucket.com/albums/y10...9698679003.jpg |
Here is the piece thats missing from the first pics i posted . This plastic
shroud encloses the radiator from the engine bay . I removed it and didnt put it back in thats why you can see the trans cooler and radiator when the hood is popped . http://i2.photobucket.com/albums/y10...9698679007.jpg http://i2.photobucket.com/albums/y10...9698679006.jpg |
(Post 4743322)
Is there a gap for the trans cooler? Do you have an oil cooler up there too?
Originally Posted by bdc95ta
(Post 4743369)
Originally Posted by speed_demon24
(Post 4743368)
Yes
Thank you :) |
See, it is not your fans at all. You removed an important piece that directs the air to the radiator. It's the same as removing the air dam.
(Post 4743690)
